Missing_feed
How to make end mill cutter in nx?
NX
By a sahu on 14 May 18:15 2 answers 541 views 0 comments
pleas suggest me comand.
  • SIMMY CHAUHAN
    SIMMY CHAUHAN about 1 year ago
    make the body of cutter by revolve/extrude/cylinder
    skech a line with require length of flute. on the plane then use command wrap> sel. sketch > then> body > ok
    the curve will be wrapped on the body of the cutter. and sweep the circle as section along the curve. with subtract option... i hope u understand
  • lara
    lara 11 months ago
    well i don`t exactly , but i have make a cylinder then make a helix curve then swept a small square on that helix , then make array (associative copy) of this swept , subtracted the array from the cylinder.
    i have submitted a part , i have i will help you , good luck
    end_mill.prt, 644 KB
    Download
    end_mill.x_t, 133 KB
    Download
Add your answer to: "How to make end mill cutter in nx?"
