how to open catia v5 file in catia v6
may not operate; 1 - version status, originality
2.- The converter may be required for operation in catia v6.
In this regard, I would recommend using catia v6 as the shortest path
If you are using pirated version of CATIA V6 then save and open options are not worked. So, I prefer use CATIA V5 instead of CATIA V6.
Hi,
Are you facing any error like...
"You need to define environment before doing this operation."
If not this error, you can even drag and drop a V5 file in V6 session.
