not able to open .cgr file in catia its coming error
make an assembly (CATProduct) insert as existing part. thats all greetings
thats all
greetings
For this you need to have IGES license and after that go to start menu, clik open file from and give the path where your CGR file is existing.
AutoCAD Autodesk Inventor CATIA NX Pro/Engineer Wildfire PTC Creo Elements SolidWorks Solid Edge Other
