how to put pistons rod at the same angle together when i assembling with crank shaft ?
I have model crankshaft with piston rod . the problem I do not know how to put them in the same angle 90 degree vertically . I try hard to put them at the same angle but I can not . please will help me many thanks to you
you would normally mate the piston to the cylinder but you can add an axis to the piston and then mate it to a plane in the attached simple example I used a plane of the bearing.
