How to render animations in keyshot 2?
I want to render a radial engine assembly animation in keyshot 2.The hing is the animation has been made in CREO using kinematics module the one in which you attach different motors after constraining the model.
you'll want to use pivot points in your animation. These are objects (parts) in your model for the redial engine bits to rotate around,also check https://grabcad.com/questions/10tutorials-_-keyshot-tips-step-by-step please
