Missing_feed
How to surface bodies change to solid bodies?
By bikan on 03 Jul 16:59 1 answer 418 views 1 comment
I want to simulate my assembly, so I saved that assembly as a part and open it.
In that part there was created surface bodies. I need to use combine, but combine does not works with surfice bodies, so I need to transform surfice bodies into solid bodies.
I tried knit surface, but it can not.
Sorry if my english is not good
Thanks for your help
simulacija_prava.SLDPRT, 486 KB
Download
1 answer
  • Sudhir Gill
    Sudhir Gill 11 months ago
    During saving the assembly.. there are three options. like outer components.. Select All components and then save it. this way you will have the multi body environment. :)
Add your answer to: "How to surface bodies change to solid bodies?"
