How to upload a rendered file from solid edge?
By Pedro Santiago on 06 Aug 23:41 1 answer 266 views 0 comments
I know how to use the rendering feature of solid edge but when I upload a snippet of the model it doesn't look clean or sharp. I render the model then use the snipping tool to capture the image. Is there a better way to upload the images so my rendering looks sharper and cleaner
1 answer
  • marek
    marek 9 months ago
    You can save it directly jpg, bmp or other image file. Application button >>Save as Image ...
Add your answer to: "How to upload a rendered file from solid edge?"
