How to upload rendering file?
By Ravinder Saggam on 17 May 07:51 4 answers 515 views 2 comments
what it means?
  • Ali Mahvan
    Ali Mahvan about 1 year ago
    to upload a rendering file you should save as the cad model in a picture format (such as *.jpg *...) then upload the photo from Renderings section
  • Greg Pavlik
    Greg Pavlik about 1 year ago
    One good procedure for uploading rendered files
    -Upload the regular files
    -Click "renderings" ( Its just the Model feed & Revision buttons)
    -Go to the "select file" box (on the bottom) and click the "Browse" button
    -Pick the file that you want to place and click the "Open" button
    -Then click the "Upload" button
    After that you should be done.
  • Greg Pavlik
    I would agree with Ali. I usually use Inventor software and in Inventor there is an "Enviorment" part, in which you would use the Rendering. When you use this Enviorment section there is a part where you can automatically save the files. Most of the files are saved as JPEG or Bitmap format.
  • Ali Mahvan
    in some case if your cad software dose not support or allow to save the model in picture format. there is another way and that is to use a print screen...
Add your answer to: "How to upload rendering file?"
