How to use Knit Surface and Filled Surface in surface command Kiffli 11 Jun, 2012 02:08 AM can anyone show how to use it 2 Answers Tony Cantrell Answered on 15 Jun, 2012 11:08 AM Knit surface is used to clean up a surface to another surface. Filled surface is to create a surface using boundries (lines arcs other surface edges). Juan Esteban Paz (JEPaz) Answered on 28 Sep, 2012 04:59 PM if you want to create a solid body you must make sure all the surfaces make a closed body then you use knit surfaces and you can select try to form solid so that it fills the enclosed surface and make it a body
