IGES IMPORT ISSUE
By Nishant Shrivastrava on 12 Jul 10:40 0 answers 260 views 0 comments
C:\Documents and Settings\nishant\Local Settings\Application Data\DassaultSystemes\CATReport\Line_Arc_IGES_import.rpt
Input file: F:\BOSS\Arti Mam\delivered\Line_Arc_IGES_import.igs
***** FILE IGES INFORMATION : START SECTION *****
START RECORD GO HERE.
***** FILE IGES INFORMATION : GLOBAL SECTION *****
Product identification from sender : CNEXT - IGES PRODUCT
File name : Line_Arc_IGES_import.igs
Systeme I.D. : IBM CATIA IGES - CATIA Version 5 Release 19
Preprocessor version : CATIA Version 5 Release 19
Number of binary bits for integer representation : 32
Single precision magnitude : 75
Single precision significance : 6
Double precision magnitude : 75
Double precision significance : 15
Product identification for the receiver : Line_Arc_IGES_import
Model space scale : 1
Unit flag : 2
Units : MM
Maximum number of line weight gradations : 1000
Width of maximum line weight in units : 0
Date & time of exchange file generation : 20120712.140639
Minimum user-intended resolution : 0.001
Approximate maximum coordinate value : 10000
Name of author : nishant
Author's organization : NIC-F366C1457BE
Version number : 11
Drafting standard code : 0
Data & time model was created/modified : 20120712.140639
Mil-specification ( protocol W.E.I.Y.I. ) :
~~~~~~~~~~~~~~~~~DETAILED CONVERSION~~~~~~~~~~~~~~~~~
Current V5 session scale is: 1
~~~~~~~~~~~~~~~~~CONVERSION SUMMARY~~~~~~~~~~~~~~~~~
OK = Transferred
KO = Not transferred
NS = Unsupported
OUT = Out of size
DEG = Degenerated
INV = Invalid
| Entity Type | OK | KO | NS | OUT | DEG | INV |
| 0 | 0 | 0 | 1 | 0 | 0 | 0 |
| Result | 0 | 0 | 1 | 0 | 0 | 0 |
Transcription time in seconds: 0.047000
Line_Arc_IGES_import.igs, 729 Bytes
Download
Line_Arc_IGES_import.CATPart, 50.6 KB
Download
Add your answer to: "IGES IMPORT ISSUE"
