Hello, everyone!
Is it possible to create a flat pattern of a helical part in sheet metal module of Creo Parametric?
Thank you in advance.
Best regards, Vladimir.
The part you have added cannot be retrived, but Im presuming you have tried the unbend feature?
Pete.
Hello, Peter.
Thank you for your answer.
At last I managed to do it.
I made a small change in the model so to get a linear edge in it, then I converted this model from a solid part to a sheet metal part (that is an interesting fact, because I initially made this part in a sheet metal module).
When I were creating a flat pattern I chose this linear edge to fix it. The result is exatly what I want.
Kind regards, Vladimir.
