Need to know if is possible run pro/e in linux
Here is a method to run 3.0 on Linux
http://ubuntuforums.org/showthread.php?t=990227It basically involves rewriting some of the scripts to adapt to the Linux file structure. I have never personally tried this but it seems like it would work.
as far as I know, 3 and maybe 4 are fine but 5 is not.
what distro of linux are you using?
any advice how to make creo 1 portable?
I'd kill for the opportunity of running creo under linux :)
