optional elements in sweep command of surface design catia v5 r21
can any one tell me that how to use a spine or the optional elements of all the sweep types EXPLICIT, LINE, CIRCLE and CONICAL. or plz help me with a tutorial of sweep features covering all the options
Spine is a curve which profile will be positioned to it perpendicularly. If you select nothing for spine, guide curve accepted as spine.
Surfaces can be limited by selecting Rel1 and Rel2. (select points for this)
Angular correction and Deviation is used with a tolerance value to deviate and deflect from curves to create a surface with small errors.
Answered with a tutorial: https://grabcad.com/tutorials/optional-elements-in-sweep-command-of-surface-design-catia-v5-r21--2
