i downloaded an inventor assembly hinge component online and constrained it. However when i place it in i different assembly file it seem to be locked to whatever view its left in the hinge assembly file.
can anyone help solve this problem
thx...william. tried that before but it didnt work. but removed a couple of extra constrains and it worked perfectly.
The extra constraints likely removed the degrees of freedom required to move the hinge.
