Problem when importing an Autocad 3D assembly to Inventor
By MECA on 15 Aug 02:59 1 answer 392 views 2 comments
Hi guys,
I received an Autocad 3D model of an assembly which I need to import to inventor. I select Open-Options-Import...etc and go through the import windows and when the models opens in the Inventor's .iam environment, several parts are not where they suppose to be, and I have to manually constraint them again into the correct position.
Any ideas on what can I do about it?? Any tips to improve the import process will be greatly appreciated!!
Thanks in advance!!
MECA
Added images
Square Square
1 answer
  • Ioannis Skarlatakis
    Ioannis Skarlatakis 9 months ago
    Quick Tip : Save your Autocad file as an .igs and try again hopefully you'll get what you're looking for!!!
    To do that go Export --> Other Format --> and on the popup window pic the .igs file type to save you file!!!
    Let me know if this will work for you
    Best Regards
    Ioannis
Add your answer to: "Problem when importing an Autocad 3D assembly to Inventor"
