i made some linked body,but if i changed in original parts my linked body is not updated
every time i want to redifind the object in order to up to date
so what i do in order to avoide such step
Hi, Try this settings change first, Tools-> Update-> Update For External Change.
Also check these settings:
Tools -> Update ->check if either 'Delay Interpart' or 'Delayed after Edit' is toggled ON.
Load Options, check that 'Use Partial Loading' is toggle OFF and 'Load Interpart Data' is toggled ON.
Assemblies -> WAVE -> Associativity Manager check 'Delay Interpart Updates' is toggled ON, or if anything shows up in the 'Out of Date Frozen Parts' dialog is on.
Hope this helps.
