SpaceClaim basic tutorial - variable spring
By Verislav Mudrak on 04 Oct 16:48 1 answer 1243 views 1 comment
How to make variable spring in SpaceClame
1 answer
  • Verislav Mudrak
    Verislav Mudrak 8 months ago
    SpaceClame basic tutorial - how to make variable spring
    1. Step 1
      1.open new design
      2.draw circle
      3.draw line
      4. select pull
      5. select revolve
      Medium
    2. Step 2
      6. select line
      7. select circle ( select surface, not circle line)
      8. select revolve helix
      Medium
    3. Step 3
      9. taper angle: 30
      pitch: 7 (if circle diameter is less, in this example, circle is 6 mm)
      height: 14
      10. enter or click in the empty
      Medium
    4. Step 4
      11. taper angle:30
      pitch: 20
      height: 50
      12. enter or click in the empty
      Medium
    5. Step 5
      13.taper angle: -30
      pitch: 20
      height: 50
      Medium
    6. Step 6
      14. taper angle: -30
      pitch: 7
      height: 14
      Medium
    7. Step 7
      Medium
    8. Step 8
      Medium
Add your answer to: "SpaceClaim basic tutorial - variable spring "
