Tutorial on helical sweep in Creo Elements/Pro aka Pro Engineer Wildfire.
Here is the tutorial.
Step 1
Start Creo in Part mode.
Step 2
Insert>>Helical Sweep>>Protusion.
Step 3
Keep the default settings and click Done.
Step 4
Select the Top Plane and then press the middle mouse button.
Step 5
Choose Default and then press middle mouse button.
Step 6
The Sketcher window appears.
Step 7
Make a center line along vertical axis and a line of 100mm at a distance of 25mm with vertical axis.
Step 8
Click done and keep the default pitch value.
Step 9
Now the sketcher again appears.
Step 10
Draw a circle.
Step 11
Exit the sketch and click done. And the helical sweep feature is generated.
