Tutorial - how to create a linear pattern
By Tanel Välja on 19 Oct 17:20 1 answer 852 views 0 comments
A simple tutorial
1 answer
  • Tanel Välja
    Tanel Välja over 1 year ago
    Tutorial here. Please note that you can either use edges or sketches to define the direction of patterns. You can pattern almost any feature, they don't have the be "merged" with the original feature.
    1. Step 1
      Start by creating a sample extrude
      Medium
    2. Step 2
      Sketch and position your feature which you will be patterning later.
      Medium
    3. Step 3
      After creating the feature, open the "linear pattern" feature
      Medium
    4. Step 4
      Select one of the edges as the direction and then select the extruded cut as the feature to pattern.
      Medium
    5. Step 5
      Sometimes you have to have 2 rows, so select the perpendicular edge to create a pattern that goes sideways aswell.
      Great work :)
      Medium
Add your answer to: "Tutorial - how to create a linear pattern"
