Tutorial how to create a simple fan?
By Andreas Gkertsos on 19 Jan 00:26 2 answers 3219 views 0 comments
Tutorial how to create a simple fan? In this tutorial , I'm gonna show you how to create a simple fan.
  • Andreas Gkertsos
    Andreas Gkertsos over 1 year ago
    These are the steps below...
    1. Step 1
      First o all we must create the hub that will hold the fan blades.. SO we create a sketch in any plane we want....
      Medium
    2. Step 2
      Then we revolve to create the hub... (can be done with extrude... its up t you..)
      Medium
    3. Step 3
      Next we sketch the fan blade, as it would be flat...(like before the pressing)
      Medium
    4. Step 4
      Then we extrude it.. (NOTE we do NOT merge result because we want to modify the blade before adding it to the hub)
      Medium
    5. Step 5
      To continue, we click on the flex feature, located in Insert->features->flex and we select the blade as a body to flex... We choose twist option from the menu.
      Medium
    6. Step 6
      we adjust the twisting planes in order to twist the blade in the desired direction...
      Medium
    7. Step 7
      After twisting, we are done with the blade treatment, and we circular pattern the blade, as a solid body. (we pattern the blade body)
      Medium
    8. Step 8
      Finally we combine the blades with the hub....
      Medium
    9. Step 9
      and the result is a simple fan:)
      Medium
Add your answer to: "Tutorial how to create a simple fan?"
