Tutorial : How to design a ball bearing in SolidWorks and show design intent?
By Krutin Rajani on 10 May 14:30 3 answers 4849 views 2 comments
Bearing is a common mechanical component.
  • Krutin Rajani
    Krutin Rajani over 1 year ago
    the link to the model is : Bearing
    Added images
    Square
    Assem1.SLDASM, 259 KB
    Download
    1. Step 1
      Open a new part and create the following sketch on a plane.then revolve it around a center axis.
      Medium
    2. Step 2
      this will create the basic outer housing of a ball bearing.
      Medium
    3. Step 3
      on the plane passing through the center make the following sketch. the circle touches the inner curved surface.the number of spokes corresponds to the number of the ball which will be inserted.
      Medium
    4. Step 4
      this will create the following outer housing
      Medium
    5. Step 5
      in a new part we will create the inner housing of the bearing. for that create the following sketch and revolve it around the central axis.
      Medium
    6. Step 6
      for the shaft to have a grip we creates grooves in the inner housing.for that make following sketch and cut it
      Medium
    7. Step 7
      you can make two grooves by using mirror feature(optional)
      Medium
    8. Step 8
      this creates the inner housing for the ball bearing.now its time to create the ball. for that in a new part create a semicircle and revolve it as follows.
      Medium
    9. Step 9
      in the central plane of the ball create the following sketch.this will be helpfull for mating in the assembly.
      Medium
    10. Step 10
      open a new assembly.insert the outer and inner housing in it. mate their respective planes and their central axis to make them concentric and lie in same plane. for this you will require two coincident mates(for making them in same plane and for making them concentric).
      Medium
    11. Step 11
      insert the balls.(i am inserting 8 balls which can vary as your wish)
      Medium
    12. Step 12
      now mate one of the marked point in the all with the arc in the outer housing with the coincident mate..
      Medium
    13. Step 13
      then mate the two axis using coincident mate to align it properly.
      Medium
    14. Step 14
      mate all the balls similarly.
      Medium
    15. Step 15
      hide the excess lines to make it look good.
      Medium
    16. Step 16
      you can also add an animation using this when using this in any further assembly.
    17. Step 17
      important thing is that "radius of the arc created on the outer housing should be equal to the sum of the ball diameter and radius of the inner surface of the inner housing". else the balls will mesh into the housing.
  • Lukasz Siwiec
    Lukasz Siwiec over 1 year ago
    Also you can use Toolbox and you have all bearings :)
  • maxikcz
    maxikcz over 1 year ago
    Missing Case balls :(
Add your answer to: "Tutorial : How to design a ball bearing in SolidWorks and show design intent?"
