Tutorial on modeling container using surfacing in SolidWorks.
Here is the tutorial.
Step 1
Top plane>>Sketch.
Step 2
Draw this profile.
Step 3
Extrude it.
Step 4
Reference geometry>>plane.
Step 5
Top plane by 70mm.
Step 6
Plane1>>Sketch.
Step 7
Draw a circle.
Step 8
Exit the sketch. Lofted surface.
Step 9
Select the circle and the edges of the extruded surface as the loop using selection manager.
Step 10
Tangency to face.
Step 11
Click OK. Again Plane1>>Sketch.
Step 12
Select the edge and then convert entities.
Step 13
Extrude it.
Step 14
Front Plane>>Sketch.
Step 15
Draw this profile using spline.
Step 16
Trim it in half.
Step 17
Draw another spline tangent to this one.
Step 18
Revolve surface it.
Step 19
Trim surface.
Step 20
Trim away the outer surfaces.
Step 21
Knit surface.
Step 22
Select all surface and uncheck gap control. Check merge entities.
Step 23
Fillet.
Step 24
Select the edge of the extruded-surface2.
Step 25
Thicken.
Step 26
Select the surface and thicken it outside.
Step 27
And we have the basic surface of the container.
Thanks for the tutorial everything worked as planned, except steps 9-10.
I had to create a sketch on the rectangular top edge in order to have a closed sketch. (SW wouldn't let me simply select the top edges ).Thanks!
