This is tutorial on making crank shaft. The main problem with making such design is with reading the dimensions on the drawing sheet. Well i have solved it for you. In this tutorial we will go through simple extrusion operation to make crank shaft.
Step 1
Right Plane>>Sketch.
Step 2
Draw a circle of 120mm and 4 holes of 12mm at 42.5mm from origin.
Step 3
Extrude it by 16mm.
Step 4
Right face>>Sketch.
Step 5
Draw a circle of 50mm dia.
Step 6
Extrude it by 40mm.
Step 7
Right face>>Sketch.
Step 8
Draw this profile.
Step 9
Extrude it by 22mm.
Step 10
Right face>>Sketch.
Step 11
Draw a circle of45mm at 40mm from origin.
Step 12
Extrude it by 35mm.
Step 13
Right face>>Sketch.
Step 14
Draw this profile.
Step 15
Extrude it by 25mm.
Step 16
Right face>>Sketch.
Step 17
Draw a circle of 45mm dia.
Step 18
Extrude it by 35mm.
Step 19
Right face>>Sketch.
Step 20
Draw this profile.
Step 21
Extrude it by 22mm.
Step 22
Right face>>Sketch.
Step 23
Draw a circle of 45mm.
Step 24
Extrude it by 45mm.
Step 25
Right face>>Sketch.
Step 26
Select this face and click Convert entities since the profile is same.
Step 27
Extrude it by 22mm.
Step 28
Right face>>Sketch.
Step 29
Convert the circular edge.
Step 30
Extrude it by 35mm.
Step 31
Right face>>Sketch.
Step 32
Convert this face since the profile is same.
Step 33
Extrude it by 25mm.
Step 34
Right face>>Sketch.
Step 35
Convert the cirular edge from 4th extrusion.
Step 36
Extrude it by 35mm.
Step 37
Right face>>Sketch.
Step 38
Select the 3rd extrusion face and convert entities.
Step 39
Extrude it by 22mm.
Step 40
Right face>>Sketch.
Step 41
Step 42
Extrude it by 145mm.
Step 43
Right face>>Sketch.
Step 44
Draw a rectangle of this dimension with one point coincident on the circular edge at a distance of 4.5mm.
Step 45
Extrude cut it by 100mm.
Step 46
Right face>>Sketch.
Step 47
Draw a circle of 28mm.
Step 48
Extrude it by 28mm.
Step 49
We have the crank shaft.
