Tutorial - Modeling Flower in Creo Element aka Pro/Engineer using Surfacing method 1?
By Sudhir Gill on 08 Mar 06:05 1 answer 932 views 0 comments
Tutorial on modeling Flower in Creo Elements aka Pro/Engineer with surfacing method 1.
1 answer
  • Sudhir Gill
    Sudhir Gill about 1 year ago
    Here is the Tutorial.
    1. Step 1
      Sketch >> Top plane.
      Medium
    2. Step 2
      Draw a spline. Exit the sketch.
      Medium
    3. Step 3
      Sketch >> Front plane.
      Medium
    4. Step 4
      Medium
    5. Step 5
      Medium
    6. Step 6
      Use the spline (i.e. convert). Exit the sketch.
      Medium
    7. Step 7
      Medium
    8. Step 8
      Draw a identical spline to that in 2nd step.
      Medium
    9. Step 9
      Now we have 4 splines.
      Medium
    10. Step 10
      Select one spline on top plane and one on front plane and then goto Edit >> Intersect.
      Medium
    11. Step 11
      This creates a 3D curve for these splines. Repeat the same step for other two.
      Medium
    12. Step 12
      Insert >> Boundary blend.
      Medium
    13. Step 13
      Hold CTRL and then select both curves.
      Medium
    14. Step 14
      Insert >> Advanced >> Vertex Round.
      Medium
    15. Step 15
      Select the surface.
      Medium
    16. Step 16
      Hold down CTRL and select both vertex. Press middle mouse button.
      Medium
    17. Step 17
      Now enter the trimming radius.
      Medium
    18. Step 18
      Now hide the interest1 and intersect2.
      Medium
    19. Step 19
      Medium
    20. Step 20
      Draw a circle.
      Medium
    21. Step 21
      Extrude it.
      Medium
    22. Step 22
      While selecting the leaf goto Edit >> Trim.
      Medium
    23. Step 23
      Select the circular surface as the trimming object.
      Medium
    24. Step 24
      Direction of keeping be outside.
      Medium
    25. Step 25
      Hide the extrude surface.
      Medium
    26. Step 26
      Select the surface and then goto Edit >> Pattern.
      Medium
    27. Step 27
      Pattern it about axis 6 times.
      Medium
    28. Step 28
      Select the surface trim and then goto Edit >> Pattern.
      Medium
    29. Step 29
      It will automatically pattern for reference. Click OK.
      Medium
    30. Step 30
      Thicken the surface.
      Medium
    31. Step 31
      Select the thicken surface and then Edit >> Pattern. Same settings and click OK. All the surfaces will be thickened.
      Medium
    32. Step 32
      Medium
    33. Step 33
      Draw this sketch.
      Medium
    34. Step 34
      Revolve it and we have the flower body.
      Medium
Add your answer to: "Tutorial - Modeling Flower in Creo Element aka Pro/Engineer using Surfacing method 1?"
