Tutorial on modeling flower in SolidWorks using Surfacing.
Here is the tutorial.
Step 1
Front Plane >> Sketch.
Step 2
Draw a spline and center line.
Step 3
Revolved surface it.
Step 4
Top plane >> Sketch.
Step 5
Draw this profile.
Step 6
Select Trim surface under surfaces tab.
Step 7
Trim the outside surface of the profile.
Step 8
Thicken under surfaces tab.
Step 9
Select the leaf and then thicken it.
Step 10
Reference Geometry >> Axis.
Step 11
Select top plane and origin. Click OK.
Step 12
Circular pattern.
Step 13
Select the thicken body as the body to be patterned about the axis 6 times.
Step 14
Step 15
Draw a circle.
Step 16
Extrude it.
Step 17
Click Dome under features tab.
Step 18
Top face of the extrusion and dome it.
Step 19
We have the flower body created.
