Tutorial - Modeling Unified screw threads on bolt in SolidWorks?
By Sudhir Gill on 24 Feb 15:26 5 answers 13652 views 0 comments
Tutorial on modeling Unified screw thread on bolt in SolidWorks.
  • Sudhir Gill
    Sudhir Gill almost 3 years ago
    Here is the tutorial.
    1. Step 1
      Start SolidWorks in part mode.
      Medium
    2. Step 2
      Top plane>>Sketch.
      Medium
    3. Step 3
      Draw a circle of 20mm dia.
      Medium
    4. Step 4
      Extrude it by 50mm.
      Medium
    5. Step 5
      Top face>>Sketch.
      Medium
    6. Step 6
      Draw a polygon inside a circle of 32.5mm dia.
      Medium
    7. Step 7
      Extrude it by 10mm.
      Medium
    8. Step 8
      Top face>>sketch.
      Medium
    9. Step 9
      Draw a circle tangent to sides of polygon.
      Medium
    10. Step 10
      Extruded cut.
      Medium
    11. Step 11
      Check flip side to cut. Draft enable at 45.00º.
      Medium
    12. Step 12
      Chamfer.
      Medium
    13. Step 13
      At distance of 3mm & angle 45º.
      Medium
    14. Step 14
      Top plane>>sketch.
      Medium
    15. Step 15
      Select the outer edge and then convert entities.
      Medium
    16. Step 16
      Curves>>Helix and spiral.
      Medium
    17. Step 17
      Defined by Pitch and revolution. Pitch=3mm and revolution = 15.
      Medium
    18. Step 18
      Right plane>>sketch.
      Medium
    19. Step 19
      Draw a profile like this. Since pitch is 3mm so keep the length be little less than pitch since at 3mm it will have intersection error.
      Medium
    20. Step 20
      Sweep cut.
      Medium
    21. Step 21
      Select the profile and the helix as the path.
      Medium
    22. Step 22
      And we have the unified screw threads.
      Medium
  • jairo luis
    jairo luis almost 3 years ago
    sudhir friend if the thread pitch is 3mm, I know because that curve 1 mm diameter and rather than be a rounding triagulo you applied it. the only thing that I did not understand step 20
Add your answer to: "Tutorial - Modeling Unified screw threads on bolt in SolidWorks?"
