In this tutorial we will go through the third step. We will review our results.
Step 1
Goto General Postproc >> Plot Results >> Deformed Shape.
Step 2
Select Def + undeformed. Click OK.
Step 3
We have deformation plot. Now goto Plot Results >> Contour plot >> Nodal Solu.
Step 4
Select DOF Solution >> Displacement vector sum and click OK.
Step 5
Now we have displacement plot.
Step 6
Again goto Nodal Solu and select von mises stress under stress. Click OK.
Step 7
We have von-Mises plot.
Step 8
Click PlotCtrls and then select Capture image.
Step 9
Now the result image will be in seperate image.
Step 10
Again PlotCtrls Menu and select Numbering.
Step 11
Check KP, Line and Element numbers & click OK.
Step 12
Now we have the numbering for element.
Step 13
Again goto PlotCtrls >> Animate >> Deformed shape.
Step 14
Select Def + undeformed and click OK.
Step 15
The animation will start. Click Close.
Step 16
Goto PlotCtrls Menu and then Animate >> Save Animation in case you want to save the animation.
Step 17
Goto General Postproc >> Plot results >> Vector plot >> Predefined.
Step 18
Keep it to DOF solution and click OK.
Step 19
We have the vector plot.
Step 20
Finally we have solved the problem in APDL.
