Tutorial - Spine feature in Creo Elements aka Pro/E?
By Sudhir Gill on 07 Mar 07:06 1 answer 574 views 0 comments
Tutorial on spine feature in Creo Element pro aka Pro Engineer wildfire.
1 answer
  • Sudhir Gill
    Sudhir Gill about 1 year ago
    Here is the tutorial.
    1. Step 1
      Sketch >> Top plane.
      Medium
    2. Step 2
      Draw a semi-circle.
      Medium
    3. Step 3
      Extrude it as surface.
      Medium
    4. Step 4
      Medium
    5. Step 5
      Change the view from planar using mouse middle button.
      Medium
    6. Step 6
      Right click and hold it. Then select references.
      Medium
    7. Step 7
      Select the end points on top plane as reference.
      Medium
    8. Step 8
      Also select the other point too.
      Medium
    9. Step 9
      Sketch orientation.
      Medium
    10. Step 10
      Spline tool.
      Medium
    11. Step 11
      Draw a spline by using vertex references.
      Medium
    12. Step 12
      Exit the sketch.
      Medium
    13. Step 13
      Insert >> Warp.
      Medium
    14. Step 14
      Select the quilt as the body to deform.
      Medium
    15. Step 15
      Click Spine tool.
      Medium
    16. Step 16
      Select the spline as the chain.
      Medium
    17. Step 17
      Type to warp radially from center.
      Medium
    18. Step 18
      Now deform the quilt using the control points.
      Medium
    19. Step 19
      Click OK and the feature is generated.
      Medium
Add your answer to: "Tutorial - Spine feature in Creo Elements aka Pro/E?"
