Here is the Tutorial.
Step 1
Start Solidworks.
Step 2
Sketch>>Right Plane.
Step 3
Make a circle let dia be 100mm.
Step 4
Extrude it by 200mm.
Step 5
Sketch>>Top Plane.
Step 6
Choose Normal to view or press ctrl+8.
Step 7
Make a centre line that passes through the axis and coincident with the centres of both the circular faces.
Step 8
Choose Text in Sketch tab.
Step 9
Choose the centre line as the curve.
Step 10
Type in the text. For example GrabCAD.com.
Step 11
Adjust the alignment (center) and the size of the text (let be 48mm).
Step 12
Click OK and exit the sketch.
Step 13
Choose Wrap in the features tab.
Step 14
Select sketch2.
Step 15
The wrap feature property manager will show.
Step 16
Choose the cylinderical face.
Step 17
Change the emboss height to 10mm.
Step 18
Click OK. The Embossed text appears.
Step 19
Click Wrap1 and choose edit feature.
Step 20
Change wrap type to Deboss.
Step 21
Click OK and you can see that this time the text is dugged into the cylinder.
Step 22
Again edit the feature and this time choose Scribe.
Step 23
Click OK and you can see the scribed sketch on the cylinderical face.
Nice tutorial. What is your preferred method of wrapping a 2 axis curve or sphere?
