Urgent Autodesk Inventor Help!! Please!!
By Nuno Felix on 12 Feb 12:17 1 answer 135 views 0 comments
I got this ipad case, that i've been working on.
So far the customer likes the model, but the surfaces in the back, need to blend together better.
The image attached shows the surfaces, that need to be removed, in other words, it needs to be a smooth transition.
Please let me know if you can help. I need this done before 2/13/2013
Added images
Square
1 answer
Add your answer to: "Urgent Autodesk Inventor Help!! Please!!"
