Valve simulation for an single cylinder engine
I have a Single cylinder engine model properly simulated with the crank angle and piston movement. Now i am supposed to add the intake and exhaust valves and make them move according to the values observed ( valve movement with respect to crank angle.) could somebody help me how i can do that . i want to integrate the valve movement in the same mechanism .
thanks in advance
