What are requests?
Use requests to ask other engineers to help you with a model or design challenge. Our friendly members often have just the solution you’re looking for.
It’s a free service but results are not guaranteed. If you absolutely need a fast solution then we recommend you order our CAD services instead.
3 comments
Branko Stokuca about 1 year ago
This is not complicated. Still you need to present the dimensions in order to have the part modeled correctly.
Greg Pavlik about 1 year ago
I can probably give you some help, but do you have any spec. or other information, it will probably be necesary before any real work can be done
Pradyumna Keshari Maharana about 1 year ago
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&ved=0CHEQFjAI&url=http%3A%2F%2Fwww.allfasteners.com.au%2Fpdf%2F3_Screws.pdf&ei=lCK4T6jqHsrprQf237zQBw&usg=AFQjCNFCSa4fMkrw_1QzOy-VxLe2X4ux9Q&sig2=EtMwHEHfm1SumuGjOxm3Lw see this this might help you find the dimensions
