accurate approximation of structural analysis on a sailboat hull
I am trying to do an approximation for structural analysis on a sailboat hull, ultimately to see what the addition of bulkheads will do for me. This has been a very tricky task for me so far.
some pressures and foces to consider:
-pressure force on one side of the keel
-pressure force on wet side of the hull
-force weight from the bulb
-force weight of the hull
-force from the sails
-pressure force on rudder
I hollowed out the hull but now I am unsure how to procede. You cannot simulate assemblies in my version of Solid Works (student) and I have the mast, keel, hull, bulb, and rudder all in separate parts. Any advice?
I am not sure, but here is a news letter I subscribe to. look under marine design on the right side of the page. hope it helps you.
http://www.cad2design.com/
I also have have a full and a student version of solid works, and I have not seen the problem you have in the student version, did you activate the plugin?
