AMD 6100 CPU and PNY Quadro 600 Graphic card. Can i use them together?
Hello friends. I have a computer.
Motherboard : Asrock 990 FX Extreme3
CPU : AMD 6100 3.3 Ghz
Graphic Card : Asus Radeon 1GB HD770 GDDR5
And RAM : 8 GB
I want to change my graphic card with PNY Quadro 600 Because i cant use Autodesk Inventor 2014 shade and render options on my computer. Did you ever see that around? Is it working together or need i change my GPU and motherboard . Ty for answers .
Heey.
For a home enviroment, a gamingcard will work fine, and are ussualy allot cheaper for the same performance.
For a working enviroment they use a quadrocard because they are a bit more reliable. but you'll probably never encounter any problems with a gamingcard
