Animation of motor wire winding machine
I am a graduate student and now I still try to make an animation for my project using Solidwork.
I will make an animation that shows how a motor wire winding machine works. I am still confused
how to make the animation of that machine winding the wire in the motor. So the process is like this: there are two parts, stator and rotating part. The rotating part will rotate about the stator while it winds the wire at the stator.
Do you think that I could use Solidwork to make that animation? If so, please give me advice how to make it, especially make the wire wound at the stator.
Thank you very much.
Hi Yuhanes,
Accordion my experiences it unable to animate wounding of wire on solidworks. You must use another software to animate it. But i have seen "" solidworks animation like your requirement. Maybe animates using another software. If anyone know what is this animation software place inform us.
Comments 3
A winding machine has contained with metal wire, string or paper, onto a middle, spool, or bobbin, which are diverse sorts of curving machines from clear manual sustain machines to complex PC numeric control (CNC) machines. All things considered, the huge piece of the winding machines has twist winding, rope winding, and relentless fiber winding. The winding machine has supported unmistakable organizations, for instance, equipment, materials and wire undertakings.for more details <a href="">winding machine</a>
Toroid winding machine is having drawing in centers with toroidal structure and it in like way quick winding machine. It contains a circumlocutory ring or doughnut shape entrancing party of ferromagnetic material like as overlaid iron, pound powder, around which wire is wound. This kind of winding machine has expected for inconsiderate layer windings. <a href="">winding machine</a>
The fundamental issue in the winding machines, which manual machines is not versatile and it's requiring more theory. In like way, the changed winding machines are performing sublimely yet it requires all the more over the top contraptions. In this way, the abrades has balanced through make of turn winding machine. Since, the machine has inconsequential effort and it can be handle basically and it shape in little scale models.<a href="">winding machine</a>
