any help for doing pocket opperation for an arc ??
i want to make pocket for my design but i found a problem cause with the sketch that i choosed doesn't make the operation because the area is inclined ..
make close sketch on a parallel plan taken above from modal
project it on face from surface work bench
apply pocket operation on projected profile
Try it
make sketch closed. or select thick option in pocket window.
Comments 2
you need loop for every basic level sketch to create pad and pocket.
Here is the example for 2 type pocket.
First one is closed sketch and second one is open sketch.
Answered with a tutorial:
step 1: Selected the pocket option
step 2: Selected the sketch
Step 3:Go to the "Direction" in pocket option and deselected "Normal to the profile"
Step 4: Now go to "Reference" in the same option and select inclined profile
Step 5: O.K. it
