Any Ideas as to why still haveing issues with downloading?
I still am haveing issue with down loading files from this site! Anyone else haveing issues as well?
I click on download option under image after I have selected the type of file to save, and then at times I get HTML or similar type junk! Why?
Are you getting a text page?
If you are save as a .step or .igs file type
Then import or open with your software
Let me know if this helps
I see this as well with step or igs files
What you are seeing is the text from the isg or step file
in IE file-save as step or igs file type
This does work
If my method works please click it worked icon
others will then understand work around until fixed
What browser are you using? Some are more compatible with the site than others.
The browser I am useing is Internet Explorer 9
the operating system is windows 7 pro
my system is a quad core xeon with 16gb of ram
I get this not only on step files or igs, but i also get it with dwg's as well as .rar and .zip files as well as solidworks files, if it was a canstant thing, i might understand, but it is once in 7 to 20 tries as far as downloads go.
Could you point out some specific files which you have problems downloding?
again still have issues with download of step/iges files
I have included a file of snap shot taken of what i get when i try to down load.
NOTE: what is in the attached file is a common things for me, from this web sight.
Hi car,
Are you still seeing this? For me, on Windows 7 in IE9, that file now goes straight to download. We fixed an issue with file header metadata that was causing the browser to attempt to open the file in the browser.
Yes, but I have been doing what was recommended, as in right click and save as. (Which I should not have to do.)
Will be monitoring to see if the issue has been fixed though.
