Anybody can tell me in details about Leica Cyclone?
I want to know more about Lieca Cyclone software. Right now all I know is that it is used for Piping and various related tasks. If possible can anyone provide the link to manuals on how to use it.
I can give you the technical version,.......
Leica Geosystems HDS Cyclone — software modules provide point cloud users with the widest set of work process options for 3D laser scanning projects in engineering, surveying, construction and related applications.
Cyclone lets users take advantage of traverse, back-sight, and resection capabilities of the new Leica ScanStation C10 laser scanner for more cost-effective as-built and topographic surveys and lets users create plant as-built models more efficiently from laser scans.
Hey Sudhir I work with it daily its used for multiple task like registering point clouds, Processing the point cloud and then to model Structural elements and piping....In detail you will cut a Wide flange out in the point cloud and tell the software to fit a Wide flange and it will find the right element size for the given country you select at your preferences, It does this for T-sections, Angle Iron, Square tubing, Channel Beam and wide flanges, it is great at piping because you select the straight runs of a piping route and will run an algorithm so find the right pipe size and bending ratios of the elbows
