assemble moving springs in assembly
hellow
i decided to do the engine in solid works but i have got problem cause i decided to do assembly with moving springs and i dont know how to do it cause i dont know how to assemblE cylinder head with spirngs with camshaft and valve. cause if i add to asebmly cylinder with valves and springs its good it works all springs moves but when i add camshaft and joint more then three mates called CAM it is over defined assembly can you help me with it ? i am sending you pictures too...
