AutoCAD & Accurender Help
I have rendered an image with accurender. I saved the rendered picture and pulled it into AutoCAD. Now every time i go to label the drawing and print the text wont show above the "image". Does anyone know how to resolve this issue?
you could try sending the image to the back using draw order. just type "dr" and press enter and follow the options. if that doesn't work check all your layers are set to be plotted. can you see the text on a plot preview?
