Best way of deleting face
I am modeling some very basic mufflers for flow and I was looking for the best way to delete the highlighted face. Current I just create a new sketch and copy entities and cut. I am sure there is an easier way of preforming this action.
Thank you in advance
have you tried using Revolved Boss?
I've revolved the sketch with thin feature around the construction line.
Please check the attached sketch and section cut of my idea.
I hope it's helpful.
PS if you insist on deleting the face after you've extruded both cylinders maybe you should play around with the Shell or Delete face commands.
Comments 2
