Missing feed
Blank help and what's wrong dialog boxes.
By Doug Herben on 08 May 16:37 2 answers 0 comments
Every now and then (probably once or twice a day) when rebuilding a model or a drawing my "what's wrong" box shows up as empty. The size of the box varies from instance to instance, so it seems like Solidworks is recognizing the separate errors I make, but for whatever reason the text doesn't render in the box. This isn't much of an issue as I usually have the wherewithal to eventually determine what I need to fix, but sometimes it's really annoying when I've got one error and I can't figure what's keeping the model from rebuilding because SW won't tell me what that single error is. Any help or insight would be greatly appreciated.
Added images
Square
  • john fall
    john fall over 3 years ago
    If this is 2014 there is a fix in SP3 which is now released
  • john fall
    If this is release 2014 and SP1 or SP2 its Solidworks these errors are supposed to be fixed in SP3
Add your answer to: "Blank help and what's wrong dialog boxes."
