Can any honest man who can solve my problem by thikening this fuel tank with 2 mm.
This fuel tank is design by surface in solid works. But i am trying to thicken it 2 mm. But when i do it then it comes to error and it can not be knitted and thicken. I need to know how to solve this problem and what tools can be use to solve this feature Also how to check the errors.
hi moenuddin, which surface are you trying to do? I did few of them and I didn't get any error.
Moenuddin,
Here`s what i made of it. The last steps in "Feature manager" show "splitt" and "shell", those are executed in the problem causing area`s. Hope that helps you a little.
If you have problems knitting, try a bigger tollerance, that may help.
beyond that: It is possible to use a "point" in "loft surface" . I have been re-doing a few of you surfaces using points.
Next to that, I have the feeling you are using "Profiles" and "guide curves" in revers order...? (Im far from a surfacing pro, but it just doesnt seem right at some of the surfaces;))
Hope this helps
