Can anybody create underbody surface of Volkswagen Passat?
hello engineers.i'm doing the project underbody aerodynamics in volkswagen passat.i have the over body model which is downloaded from the grabcad for a help can anybody create the underbody surface of that car as it should.pls sir
volkswagen passat. Just search the model in the grabcad...it model named as volkswagen passate cc pls sir
I see it has been three months and I am not sure if you are still looking for help with this issue. If you are, you would probably have better luck if you submitted this as a request instead of a question. You can do that here;
http://grabcad.com/requests
