Can anybody tell me the proper way to check for interference between two parts in a larger assembly?
I go into model analysis and select global interference. I then control select the two parts I am concerned with and hit compute. The analysis completes but it gives me all of the other interferences in the assembly. I have some interferences in by design (screw threads, press fits, etc.) so I don't want to have to figure out what are the "good" and "bad" interferences. I just want to see the bad ones which are present in the parts I select.
What is the correct way to either check only specific parts or exclude other parts from the analysis?
