Can anyone help me by solving my desing. That i have uploaded.
I want to thiken this chain cover both side 1.5mm. And you have to do a 1.5 mm extrude cut following on my desingn split line will be the extrude cut area. How can i do this. Have any noble person to solve my problem.
you should better learn it. and then use it. :(
Anyway here is the solution Two loft features are wrong. until the loft are not solved you can't thicken that surface.
