Can anyone help me how to draw this type of inclined extrude in autocad drawing attached?
I am not able to draw this type of inclined extrude can anyone tell me step by step how to draw this drawing ?
I have attached a pdf file YATAK.pdf which goes through a method to make this model. Have a look at it as it may help you.
One point to clear up. Is the object of this problem for you to work it out using autocad, a 3d or 2d dwg.
Doesn't doing this leave one with an elliptical shaped (non-drillable) hole?
Maybe that's ok since it's an exercise, it might even be the intent of the exercise based on the look of the dimensioning scheme, but in reality it would be more practical if the hole was circular.
Comments 4
