Can anyone help me out with welding of two hollow tubes in Catia V5?
I am trying to weld two hollow tubes of different cross-section:
1. Square hollow tube of dimension 49.5 mm (Length) X 49.5 mm (Breadth) X 2.60 mm (Wall Thickness)
2. Round hollow tube of dimension 50 mm (OD) X 47 mm (ID) X 3 mm (Wall Thickness)
Material: Mild Steel Grade A36
Images attached for detailed description.
I have attached image of the methods I tried, but still facing some issues.
Current Problem: Still unable to weld the side walls of the square tube with the round one. Tried methods fillet weld, but weld, v weld.
