can corel 2d design be imported in solid work or not
hello sir , i want to import 2d design from coral .cdr file in solid work or catia . so that design i made in coral can be used in solid work for 3d design
You could try to export as a TIFF/PNG image and then use the Sketch Picture option in SW and autotrace the 2D design.
Another option is to export as DWG/DXF format and import in SW as a new part 2D sketch.
Good luck!
