Can I do modal analysis in Creo Simulate? If yes, pls provide me with procedure?
I want to do the modal analysis of a honeycomb panel. I tried ansys but found it difficult. Pls help me do it with Creo Simulate.
Yes..You can do modal analysis in Creo Simulate.
It can be run on both constrained and unconstrained model.
In case of constrained model, load application is not required.
After setting up the material properties and the required constraints, go to analyses studies>File>New Modal, enter the number of modes and click run
